- Hi
Console is giving out loud noise. you can hear it from the video i've attached.
Should i get a Bios upgrade kit?
Please advise.
Thank you.
Best,
Raja Yusuf
Please advise.
Thank you.
Best,
Raja Yusuf
Hey,
has this behavior changed or was it like this since you started using this Ion Xe ? The BIOS upgrade process could be necessary, however I'd recommend getting in touch with ETC Technical Services to make sure troubleshooting is going in the right direction before you order something that doesn't fix your issue.
Technical Support (etcconnect.com)
Cheers,
Matze
