VMS - FX Layer - Why is my "End Color" palette not showing Color Swatch
I am in need of some assistance. I am programming color palettes for the pixel map FX layer.
I have programmed the "Start Color"s I want into Direct selects - everything works great. Data is stored. and the bottom corner of the direct select shows the correct color swatch.
I move on and programmed the "End Color"s I wanted into direct selects - everything works great, data is stored - but no color swatch shows up on the direct select button.
I attached a photo.
This isn't normally an issue I guess for some, however in my show file i have many macros, and quick select buttons made into magic sheets and i have areas that reference what color channels are in. and due to the direct select not showing the color swatch is really messing up my flow etc.
Is it because the direct select color palette only sees Red, Green, Blue and NOT Red2, Green2, Blue2??
Can someone help me out with this please. I am running on v3.0.1 / console and nomad.
Many thanks,
-J
