When I make between Solaframe Theatre and Solaframe 750 I make circ 100 color copyto 111 they don't copy exactly the parameters.
But if I copy magenta or cyan or yellow they copy exactly.
I use V3.0.1 with nomad PC.
Circ 100 have colorpalette and it's solaframe theatre.
I have HUE/SAT activated
when you copy the whole color set the console tries to match the resulting color. this might need different parameter values depending on available gamut of the two lights.
if you want to copy the whole…
if you want to copy the whole color set while making sure you get the same numbers you can use the DMX softkey: [Chan 1] {Color} [CopyTo] [Chan 2] {DMX} [Enter].
Thanks Ueli, I didn't know the copy with {DMX}..... Perfect.
