Does the EOS family consoles support incoming position tracaking data from the PSN protocol? Either directly or with a workaround?
Thanks! :) JM
Thanks! :) JM
At present, there is no support for PosiStageNet or other tracking standards like ANSI E1.59 Object Transform Protocol (OTP). You can stream XYZ values using OSC from third-party applications though, some of which support PSN.
You could take a look at something like LightStrike for instance. Full disclaimer, this is my application, and there may be others available.
Right .Thanks for the immediate answer! :)
