Custom Fixture Profile Issue v 3.0.1
Running into a weird issue when building a custom fixture profile. My programming class is building custom profiles and it's happening across multiple consoles and nomads.
While building a new fixture profile and trying to enter range data for some parameters like color select whenever I insert a new range I get a "ranges many not overlap error" by the nature of adding a new line to the range table things overlap until you can edit the data, but every new line triggers the error and kicks you out of the range table. Is anyone else coming across this? (it worked fine when I tried the very first range table in the fixture profile, then when I started a new parameter and new range table it happens every time I try to add a range)
