Nomad 2.9.2 on Mac OS 10.14.6 with fixture library 2.9.2.10. In edit screen for patch the Update Profile button does not highlight and the Update All button doesn't appear.
What should I try?
Lloyd
What should I try?
Lloyd
Hey Lloyd! {Update All} was not added to Eos until 3.0 so will not show up in previous versions of Eos.
The screenshot you posted shows the {Update Profile} button lit up. If you select a fixture in your list and click {Update Profile}, does it not work? I was not able to replicate this particular issue on Mac or PC.
Yes it is lit but clicking on it does nothing. Good to know about the Update All being added for 3.0.
Here is the show file:Paliku Template 2-9-2 2021-02-21 11-39-22.esf
Hey Lloyd! I'm seeing the same thing on your show file but I'm having trouble replicating the issues from scratch. Can you tell me a bit about the history of this show file? What software version did it originate in?
This show file goes back several years. The earliest version I have in my show archive is 2.6.2, but it probably was earlier. I will try step by step merging into a new file starting with patch and see what happens.
Created new file and merged in just the patch from the problem file. Same thing happened so it is something in the patch. I'll try merging half the channels at a time and see what happens. If I have to recreate the whole patch it will not be too awful in 2.9.2. Would hate to have to do it in 3.0.1 with all the position data.
It wouldn't update the profile for a one channel merge into a reset system blank file. I'll start recreating the patch.
