Possible Global FX Fader Filtering Bug?
Running 3.0.0
I'm using a global FX fader filtered to a specific set of channels to control rate. The fader will also control the rate of fixtures not in the filter that are running the same effect.
For example, I have an global FX rate fader filtered to chans 601> 605. Chans 601> 605 and 701> 704 are running effect 901. If I adjust the FX fader it will change the rate of all the fixtures running effect 901.
My workaround is to copy the effect to a new number for each group of lights I want the effect to be running on. Which is quite bothersome when busking with a limited screen real estate.
I've run into the issue on a Ti and Nomad.
