Bug: String UDP adding bytes
Hello everyone. I am not sure wether this is a bug or a feature. When sending a UDP String with Pandoras Box, only 15 bytes are beeing sent. When sending from Eos, another additional two bytes are added which results in StreamDeck not recognizing the String.
ETC EOS adding 0D 0A to the data, which will not be recognized by the StreamDeck
Pandoras Box Widget Designer sending without additional bytes, which will be correctly.
Is there a way to change this sending behaviour?
Thanks in advance!
