When adding a UDP string, the command will be shown in the external link collumn of the PSD. When adding a OSC command, nothing will be shown.
Are you using OSC Send String? That is a cue list level operation and is shown in the Cue List Index, not individual cues.
Hello,
I am using the function called "OSC Cue TX String" under Cue -> Execute
It is only triggered in the cue where I am adding the string.
You're looking for Cue Execute String. OSC Cue TC String is only available for the whole cuelist as Scott said.
Gotcha! I think the labeling of the buttons is not ideal: OSC TX should only be visible when pressing "Cue 1/" and String should make a difference between UDP strings and OSC strings.
