Hello
I would like to edit this multi cell fixture group.
I'm trying to add : (1 Cell 1>20) insert before 1 Cell 21
But it doesn't work. What is the correct command line please ?
Thank you
Hello
Thank you
In a group the order is of no concern. So just add them to the back. Or else clear the group and rewrite the whole order again.
Hello
1 / Yes, the order is important. By pressing [next], all fixtures will be in group order. It's also important in effects.
2 / I know I can delete the group and rebuild it, but that's not the point of my question.
Thanks anyway
i tryed a copple of methodes but couldn't make it.
But i found a workaround for your spezil case.
Since cell 21 is in the first subgroup, you could reverse the group.
after that simply add cell 1thu 20 by:
[+] 1.1 thr 20 [enter]
and rever the group again.
Subgroups are not realy editalbe, i think.
will this work for you?
It works in this very special case. Thank you !
Yes it seems that subgroups are editable when they are composed of simple fixtures, but not with multi-cell fixtures.
Interesting. I Always thought the group was just a selection tool. So I've learnt something today. For what purpose would the order of a group be important then? Just for effects?
Effects, command line fanning and the Next/Last order within a selection
