issues with my eos
     I've been working on an eos for alittle over a year and have started to notice some issues.  I was recently setting up some snapshots to move around my direct selects, one of my options was a 100 display of color pallets.  When I tried to return to a display filled with groupings of 20 my direct selects were...distorted.  I couldn't  use any of them and I could not return to the previous display.  The only way to get it to repaint correctly is to exit the eos and then restart.  I tried it several time and every time it did the same thing.
     The other thing that has started to happen is that my encoder touchscreen has started to act funny.  At the end of a cueing session I tried to get a rotator to work.  At first I thought that maybe there was a communication problem.  So was not going to stress about it and just deal with it the next day.  Because we were pressed for time I didn't get to work on it untill late in the day again.  With the same result.  The Next day I tried to make it work, and everything was fine.  The encoders worked, the lcd touchscreen worked, it was like nothing was ever wrong.  The only difference was that it was the beginning of the day and not several hours into a cueing session.  By the end of the day though the touchscreen was acting up again and I could get them to run the rotator.
     Was wondering if anyone had started to see any problems like these.  Or noticed anything acting up after the board has been running for a long time.
thanx
