I am trying to see if there is a way that I can add a discreet fade time and discreet delay time to the intensity and color parameters on a set of LED fixtures when releasing them from a cue. When I apply the release command in blind and give them a discreet time/delay all the fixtures fade in the time of the cue together. I tried allowing the values to track for the color and intensity, I also tried changing the values to see if that would make the fixture respond to the discreet time. Neither way worked. Is there a way to do this? Thank you.
