Hello all,
The current behavior for the desk is-When applying a text field inside the selection field of a MS object that has the fill linked to channel intensity the default behavior currently is to ignore the users font color choice and be white text for values under 100% and black text at full. This limits the users choice on where to place the text field for MS objects to outside the selection field if the user wants to use the color of the text as a visual indicator for they type of fixture.
Columns 1 & 2 have the fixture ID located inside column the fixture ID is located outside. The ID text selected to be Blue. Col 1 has a normal yellow fill Col 2 has the fill linked to the Intensity.
When the text switches from White to Black at 100 % the Fixture ID disappears. While this might be expected behavior it would it be possible for the user be able to make sure the text stays the color chosen instead of defaulting to white/Black as is current behavior.
Thank you,
Martin Weeks
