Bug Lamp Control Hold "gets stuck"
Situation:
We use Lamp Control to Switch our HMI's on/off and in the same step turn on/off the cooling fan of the MagVaders.
Lamp Control sets the Cooling Fan to 255 or 0 on hold.
Problem:
If the Cooling Fan is "hold on 0" through Lamp Control for a while (~1h, still researching) it is not possible to switch it on again (hold on 255 seems not to go "over" hold 0)
This occured on 3.0.2.6
Additional information:
On 2.X it worked perfect:
HMI OFF: HMI shut off, cooling fan was "3 min on 255" then "hold on 0"
HMI ON: HMI started, cooling fan from Lamp Control "hold on 255" but additionaly controled by Fan Curve which was perfect behavior!
