What's the "x" next to some of my channels? I'm on a GIO running 2.9.0. thanks
x should be a broken referenced mark
what does that mean?
like this?
your showfile was programmed with a feature called Referenced Marking. that's a feature where you can tell a light in which cue it should mark (i.e. prepare itself for the next position/color). if you later turn on the light between the cue where the light was told to mark and the cue it was told to mark for, the console will tell you that your mark broke (e.g. it can't prepare for cue 10 in cue 3 because the light is in use in cue 5) by showing you the x in the cue the light is marking for.
