Since Rem Dim seems to not be the right option, ( Rem Dim: Option to remain in Rem Dim ), what is the right option to quickly select a single fixture and turn all other fixtures off - for example to make changes to a moving light position?
Highlight is the tool I have used and see most programmers use.
I second this. Highlight is exactly the right tool for this purpose.
Great, thanks!
Well Highlight does work, but doesn’t turn off any light. Unless it is used with remDim.
ie: If a more or less bright cue is on stage and you want to correct that ML, highlight remdim is the one to use.
I found out, that you can set the Highlight Value to 0 in the settings, then it should work as expected.
