Reselecting Channel with Parameters
Is there any way - and if not, could there be? - of reselecting a channel plus parameters on the command line?
In other words if I go:
1 thrust b thrust d 50
then I want to change it to 60, I have to type the command again, since select-last just posts the channel without the parameters.
Closest workaround I can think of is shift-enter to recall the last command line, but then I have to clear back to get rid of the old value and type the new value.
Shift-select last doesn't seem to do anything, so could that be 'reselect the channel and selected parameters'?
Just a thought.
Rob.
