I know it's a baby block but...
(using 1.4.5 offline pc, 1.4.2 console)
I wonder if in some future version it would be possible to indicate on the cuelist "B" column whether a baby block was intentional " b " using the BLOCK command,  or an autoblock " b " (underscored)  caused by modifying a level in a prior cue.  This would be handy when performing block clean-up.  The priority would have to be given to "b" if there are any intentional blocks.
I've found it useful to split a block cue into parts. This is possible with the ASSERT flag set on a per parameter  basis.  This way I can avoid scrolling fade outs and flyaway movers that usually happen when I modify NI parameters in a prior cue at the last minute.  The problem is that although all parameters end up as blocked or moving, the cuelist indicates a partial block " b ".
