Macro: On/off for moving lights - starts "randomly" in 1sec
We need to build a macro for our magic sheets for all our relays. When we selected our ON/OFF relays for the perfromance we would have them started randomly or in groups in a timeframe of ~1sec so we don´t start all moving heads at the same time with one ON-button "as usual".
"We" have built a macro that works when we select more then one relay and it starts in groups of 10 relays using NEXT-function. It works from 2 relays. When we choose one relay and we have built the solution around NEXT, it automatically runs the next 9 relay after we trigger the macro.  We use use from 2, it works ok.
We try this in a macro:
"Offset Num_Groups 10 Interleave • Next Intensity_Palette 1 Time 0.1 • Next Intensity_Palette 1 Time 0.2 ---> • Next Intensity_Palette 1 Time 1.0"
Is there a better solution or a trick that we can use? Use selected channels and randomly/group by x relays, start them in a 1sec timeframe, so we don´t start allt relays at the same time. That works with 1,  2, 7 or 100 relays, depending how many we select.
Changes some spelling
[edited by: MacTommy at 12:35 PM (GMT -5) on Fri, Aug 20 2021]
