'Edit' Softkey gives no indication of being pressed when editing subs
A silly little detail:
Double hit sub to blind-edit a submaster.
Press the 'Edit' softkey. Nothing changes on the softkey - ie. there is no indication it has been 'pressed'.
But it has - if you type a number you're now entering chan nums rather than sub numbers.
As soon as you type a number, the 'edit' softkey goes away. But it should go away when pressed, as it does when editing presets/palettes etc, otherwise you're left wondering whether your touch has been registered.
Rob.
