I've regularly created Effects, saved them in regular subs and used them in cues. What is the difference and/or advantages of using a "Effect Sub"?
You only can store effect data in effect subs. For example if you change the sub type from additive to effect the desk automatically deletes all other intensity, color focus and beam data except of the effect. If that's an advantage or disadvantage depends on the situation I guess.
Ok, well that explains a lot. My own 'save to regular' sub does work but I sometimes do get odd things happening. When this show is over I will create some effect subs and save to them. Thank you
