We replaced our Chan 1/2 D20 dimmer pack with a R20 Relay to feed 120vac to our MLs.
[Park][Park] shows them at FL and back in live, chans 1 and 2 show the little "p" bottom left. Everything works exactly as it should. MLs wake up on board coming up and go out about 10 minutes after shutdown (because the SENSOR CEM had a loss of DMX safety time). So far so good.
I was learning about the blind spreadsheet when I saw several cues had values in those two channels! and in going to a cue which showed such values here they also appeared in the tombstone.
So I cant see how a/ these values got there (but assuming finger problems) and b/ if clearing them out will/would effect the parked FLs?
Am I missing something?
