Using Newest release 3.1, currently offline on Mac running Big Sur. Patching a House light system with multiple (30-70) parts on each channel and setting coordinates for each part in Augmented. I was trying to give each selection of Parts per channel a ranged X value of -20 thru 20 as you can with channels. All parts retuned an X Value of the first integer entered in the range. The outcome was the same each time I ran the operation with coordinate ranges differing in value and XYZ parameter. I confirmed that the operation works as expected with single part channels. I confirmed that each part will except separate coordinate sets if entered on a per part basis. Batch entry would be much more helpful. Can this be confirmed as a bug or is there a reason for not allowing the batch entry on multiple parts.
