Hello.
I see there are new profiles in the library for Astera NYX bulbs, but the description does not make it clear as to which number of Astera profile they are referencing.
So, I am attempting to create a profile for an Astera NYX Bulb in Profile 89.
Here is what I have been able to recreate in the ETC Custom Library. I have referenced the Astera parameters from Astera info and the Titan Profile 89 parameters in the ETC library.
DMX Footprint: 5 Parameter count 10
#/ PARAMETER / DMX / HOME / RANGES
1 Intens / 16b: 1,2 / 0 / 0>100
2 Color Temperature / 8b: 3 / 0 / 0>100
3 Tint / 8b: 4 / 128 / 0>100
4 Color Crossfade / 8b: 5 / 0 / 0>100
5 Red / Virtual / 255 / 0>100
6 Green /Virtual / 255 / 0>100
7 Blue / Virtual / 255 / 0>100
8 Hue / Virtual / 0 / 0>360
9 Saturation / Virtual / 0 / 0>100
10 Brightness / Virtual / 255 / 0>360
Here is what Astera provides for the the profile 89 parameters: Astera NYX Profile
89: D CCT GM CRO RGB (PIXEL = 1; STROBE = OFF)
CHANNEL V ALUE PERCENTAGE FUNCTION
1 0 - 255 0 - 100 Dimmer (closed --> open)
2 0 - 255 0 - 100 Color Temperature (CCT)
Formular: CCT = 1750 + 32*DMX-Value
Example: 45 --> 3190K
70 --> 3990K
117 --> 5494K
3 Green / Magenta Point
0 - 4 0 - 1.5 No effect
5 - 255 2.0 - 100 -96.1% --> 100% Formular: G/M = 100%
* (DMX-Value/128 - 1)
4 0 - 255 0 - 100 Crossfade (0 full CCT, 255 full RGB, smooth fade)
5 0 - 255 0 - 100 Intensity Red (0% --> 100%)
6 0 - 255 0 - 100 Intensity Green (0% --> 100%)
7 0 - 255 0 - 100 Intensity Blue (0% --> 100%)
The last 3 parameters (Hue, Saturation, Brightness) are inserted by default by ETC and cannot be deleted.
Can someone tell if I have doing this correctly?
