GIO@5 and ION Xe, version 3.0.2b6
Remote Startup works as expected, Remote Shutdown doesn't.
The options are activated on both consoles. When shutting down the Master (GIO@5),
the Backup want's to overtake control instead of shutting down.
Which network port is being used on each unit?
How long are you waiting between sending the network shut down command and shutting down the primary?
Maybe I misunderstood something.
When Power Up the console the Backup also Powers Up, but on Power Down it doesn't work?!
It is a very inconsistent behavior. The manual says that this must done in Browser > Network > Power On/Off MultiConsole System.
I can remember that this works on an older software version.
Is it possible you have a startup macro set on the console that is sending the power on command?
I will have look to console next time when I'm in the theatre.
Is this issue still around? please let us know here, thank you.
