Hi all,
when I use reference marks in combination with the cue link and loop attribute, the mark does not work as indicated, when the mark cue is the last cue of a loop.
E. g.
Cue 1
Cue 2 M Link 1 Loop 2
Cue 3 R
I would expect the eos to mark the lamps from cue 3 in cue 2 in the last iteration of the loop, which is not happening.
I have attached a short showfile to help understanding the issue.
In cuelist 1 cue 2 links to 1 (loop is set to 2)
Cuelist 2 contains no loops where the reference marks work as intended.
I'm using eos version 3.1.0 Build 282
Loop Mark Issues 2022-01-10 17-30-31.esf3d
Best regards
Johannes Felber
