Multiple selections running the same effect
Hello all,
I am running V3.1 on EOS TI.
I am having an issue with my effect playback not working how I would expect.
Previously if I applied and effect to Ch 1-5 and then applied the same effect to Ch 6-10 I would have 2 separate iterations of the same effect running on an even trail across each selection.
Currently I am attempting to do this. While working the effect playback looks as expected. As soon as I update or record the playback resets and is now running as if I applied the effect to the channel selection of Ch 1-10, with a single iteration running an even trail across all channels.
Is this a change or a bug? Does anyone have a recommendation to achieve what I'm looking for other than duplicating the effect?
Thank you for your help.
