Bug: [Ch 1][Thru][5] [Recall From] [(tap)3] returns syntax error
[Ch 1][Thru][5] [Recall From] [(magic sheet tap channel 3] returns syntax error. Tapping a channel in an already specified range after pressing Recall From will return an error insted of recalling from the channel. I think this wasn't a problem before v3 if I remember correctly.
Workaround is to type in channel 3, but having the ability to tap again would be great! Miss that one!
All the best
-p
