Hue/Sat discrepancy with color picker v1.4.5
(ver 1.4.5 offline)
When I select a scroller frame with the color encoder, the Hue and Saturation levels don't match what the color picker generates when I select the color that way.
Example:
Gam 180 "Cherry" produces Hue = 340 and Saturation = 55 (55.3 with the data key pressed) using the encoder.
Gam 180 produces Hue = 356 Saturation = 54 on the command line with the color picker.
This is true of every gel I've tested so far.
I like to copy the gelstring HS values to CMY mixers to avoid running thru the color picker a second time. This discrepancy is really annoying.
