Hi all,
Newbie here again.   Element 2   EOS V3.1    NON-tracking mode
How can I pause, hold, stop or freeze all effects running in a cue?
Thanksomuch.
Hi all,
Thanksomuch.
For playback it's irrelevant if your tracking or not. Only when recording, editing, updating, copying, moving or deleting cues tracking or cue only will influence the result.
Chan 1 Effect Enter will stop the effect.
Effect 2 Rate 0 will pause the effect in a way that's recordable into a cue.
There's are also a StopEffect and a Freeze function. On the element they are available through the softkey Fader control (softkey 5 with an empty command line)
