I have a absolute fx placed under a subfader. The order of the steps is random. Is there a way to use the bump button of the fader to manually go to the next step? So everytime i press the button, the fx goes to the next step.
No, not with FXs. You could use a cuelist instead.
But my problem is that I need the order to be randomly
I know what you mean. But right now the only option of manualy taping the next instance is a Cue or a temp Faderstack.
What should your Absolute FX do? maybe there is a other way around.
