Is it possible to copy values for a fixture between different cues? For example, this is what I’m trying to do:
cue 1 recall channels 1-15 copy to cue 2
If you are in Cue2, you can use:
1 [Thru] 15 [Recall From] [Cue] 1
You can also use
1 [Thru] 15 [Recall From] [Cue] [Last]
And if you are in Cue 1, you can also use
1 [Thru] 15 [Record] [Cue] 2
Edit:
Don't forget to record if you recall in Live, because it is still manual Data!
I will try this, thank you!!
