I would like to apply two effects to a Titan tube at the same time: a linear intensity effect [effect 1] and an absolute effect to change color [effect 2]
Make sure your effects are scoped to the intensity parameter and color parameters, respectively.
Channel 1 Intensity Effect 1 Enter
Channel 1 Color Effect 2 Enter
To call them at the same time you may use a Preset or a Fader/Submaster.
Right know there is no way to call mutiple FX from the commandline at once.
