Been running several shows for a long time now and want to really clean things up next break. How do I best find what EOS Sofware, Ele2 firmware and Fixture profiles lists am I currently running and the where can I look for any upgrades?
when you open aAbout with an empty command line you can see which software version you're running. installing a softwareversion also puts all current firmware versions on the console's harddisk. thos can then be installed from Shell > Settings > Maintenance. the software's release notes also tell you what the current firmware versions are that go with that software versions.
Thank you ueliriegg
