I´'m using version 3.1 and after I patched any fixture , I can't use the image of the gobo in my magic sheet or as icon of a beam pallet in my direct select. What could be h
appening? Any ideas?
Is it possible you ran into this bug? Eos 3.1 BUG: Clearing Any Targets Dumps All Imported Magic Sheet Assets - Eos Family - Eos Family Consoles - ETC - Community
If so, it is resolved in v3.1.1 which is currently available in Open Beta.
As a check-up, you could try the following:
- Exit to the Welcome Screen
- Deep Clear
- Start as Offline or Primary
- Patch your fixture
- Import the Gobo via the manager/ "Organizer" in Magic Sheets
- Drag it into a Magic Sheet
- Add it to a Beam Palette.
If these work properly, I think it's highly-likely that you ran into the bug discussed in that forum post that I linked.
I instaled 3.1.1 and the problem is the same
Hi Andre SP would you be willing to post here or email me your showfile and that Gobo image you want to use? mattp @ etcconnect.com
I sent the file in your email. thank you
