Bug: Inconsistency when hitting Live/blind
I have a snapshot that puts tab 2 PSD foward. In the same frame í have Tab 1. When I recall the snapshot, the PSD is selected. Now if I then press Live, focus will shift to a magic sheet channel display in another frame. If I press Blind I will enter Blind and the magic sheet channel display will also be selected. The tabs that are open stay the same, just the focus changes.
After that, I manually tap and select Tab 1 and then go back to the PSD. Then when tapping either Live or Blind I will always pull Tab 1 forward. I do not want to view tab 1, I already have a channel display magic sheet visible. This behavior will only start happening after manually tapping tab 1. The frame is locked all the time.
  • This has nothing to do with the magic sheet as such, it's the general rule for channel displays:
    Live brings you back to the last channel display tab you had previously selected.
    So when you're in PSD and press Live, the console will go and look back what the last channel display was. In your example this is Tab 3 for the first example and Tab 1 for the second one.
