This is probably reported byt I do it anyway because it is still there in 3.1.1
I had this on a gio and a @5(?) On 3.1.0 and 3.1.1
I usually remove the extra bar in tab 1 at the bottom and only show channels in that tab.
But if I stores it in a snapshot and then loads another showfile, empty file or so with the bar added (default layout) and then go back to my first file and load my snapshot the bar is still there. I have to run the snapshot once more to get the result I want. It's like the first run of the snapshot only load "what tab where" and then I have to run it once again to get the layout inside the tabs.
I have not done big investigations on the exact behaviours of the console, if the bug can be done in the same file and so on. I just noticed that what I described and maybe can do some more on it in the weekend.
Johannes
Added consoles and software versions.
[edited by: jolsson at 7:28 AM (GMT -5) on Fri, Apr 15 2022]
