I'm trying to go from cct to colors, and no combination of profile and head settings is working.
What am I doing wrong?
Kino Freestyle 21 P3 CCT RGB 8b ?
16 bit but yes. Color crustaceans has no effect and I'm confused. Going to look at the firmware version on the ballast. Fingers cruse.
I have have not used Kino Freestyle. But other products normaly have either CCT or Color.
Not both at the same time.
i found something while searching the Manual.
Firmware 4.0 says: * Red, Green, and Blue only active when Green/Magenta < 3
on Page 4 of the DMX Table.
Can't find it in Firmware v5 anymore.
Exactly. This unit is not moving to colors, in any mode, no matter what tint/gel/xfade is used. The colors do exist, because when I mismatch the profile on the ballast and the console, I get random party colors.
And What firmeware do they have?
4.1
hmmm, i double checked the Manual and the Fixture library for the Freestyle 21.
I am out of options.
Maybe you give the Unit a factory default, disable Wireless. And check again.
Thank you. Glad it isn't just me
Factory reset p8 cct rgb 16
On others, turn tint off in ML control to get colors.
This is not working.
Y???
