Hi ETC, et al.
I've just upgraded my consoles to 1.4.5, and the remotes to 2.0 (basestation) and 2.0.2 (hand held).
I've noticed that when charging off the USB wallwart, the unit thinks it is on.
If you touch a button to wake it up, the screen says "Direct USB" and the next 3 text lines are boxed in. (I'm not too concern about this issue).
The buttons also remain backlit. This is the issue I'm concerned about.
Previously, I have left the remotes on the chargers unless in use. Between our production schedule (1 night shows, and not being used for days or months) and multiple operators, I didn't see any advantage in trying to attempt some charging method, like charging it the night before the show.
Is it bad to have the backlight on 24/7/365? Is it bad to leave it on the charger 24/7/365?
How long does it take to charge the batteries? If the operator used the RFR for 1 hour to focus, charges it during the event (2 -3 hours), adn then unplugs it, will that be enough so the next operator 4 days later can focus her show?
Can the unit not power up when charging?
I also noticed when updating the firm-ware, that I had to boot up the RFR while holding the More SK button (as instructed), and THEN plugging the RFR into the USB cable to the console. If it is plugged in first, the unit is active, regardless of the position of the power switch.
Andrew Riter
Chan Centre for the Performing Arts,
University of British Columbia
