Hi!
There seems to be a display bug in the Blind macro editor display, which causes the cursor to move position relative to the yellow element of the macro content that you're editing, as you progress across the display from left to right. It effectively moves further over to the right, as you page across the contents of your macro command line, until it becomes "out of sync" with the yellow indication, and is actually on the wrong side of the content you're editing - the right hand side - by the time you are on the far right of the display. It's then quite difficult to tell which part of the macro you're editing/deleting!
Hopefully the photos clarify my above ramblings a little:
Nadene
