Hello,
Is there a way to record the Shift into a Macro?
When I am learning a new macro and use the shift key...nothing shows up.
What I would like to do is create a macro for the "Shift About" function.
Hello,
In macros Shift doesn't register as Shift. Eos will (usually) register the resulting command. E.g. Shift+Label will register Note.
So if Shift+About doesn't work it's not because Shift doesn't register, but rather because Shift+About is not macroable.
Thanks Ueliriegg.
