Hi there, is there a way to know which cues in a show file certain effects were used in? (Like, if I have Effect 400 and I want to know which cues it's been saved into) Thanks!
You can see this information in the About window, but it can be a little hit or miss bringing that window up in the CIA since the effects display also lives in the CIA. To see it, follow these steps:
[Effect][Effect]
[Effect][400][Enter]
[About]
The alternative is to open the About window in a frame. It's Tab 29.
In the PSD(Tab2) there is a column called Effects.
This column will list the Effects used in the specific Cue.
