Not sure if this is a bug, or intentional, but it’s frustrating especially since Win7 prevents use of the power button on the Classic Element to shutdown the desk
I created a macro to run Power_Off Confirm_Command Enter which is attached to a button on a Magic Sheet to power off the console
This works perfectly if not in Limited Expand Mode. However, with the desk in LEM it fails (if a command line is visible if shows “Confirm Command - Error: Syntax Error” momentarily)
it seems it’s not possible to shut the desk down cleanly from within Limited Expand Mode?
There must be a way around this? I’ve tried a macro to call power off as above, I’ve tried command to send /eos/key/hard_poweroff twice locally … none of them work under Limited Expand.
