Today i create several groups.In this groups i do subgroups.Like:Group 1 [1+2][3+4][5+6]Group 2 [10+11][12+13][14+15]
Then i load via Direct Select my groups on the touch screen at my GIO Desk.If i select now via Touch at Monitor the Groups 1 and then try step thru the subgroups, the NEXT Button not select Channel 3+4, he select Group 2.If i select the Group 1 via Syntax in Commandline, the Next Button steps thru the group as expectedThis also happen if i -after select the Group via Touchscreen- click at screen that shows the Channels.So the golden Border is active at Channelview and not at Groupview.
Have i pass some in Change Notes or is it a bug?EOS 3.1.1. last Build
When you click on a Direct Select, it places that target on your command line unterminated. So it's Group 1 _ (waiting for more input). So, press Enter after clicking that Direct Select, and you'll be able to Next/Last through the channels in the Group.
The same thing happens if you type on the command line
Group 1 Next
It will change to be Group 2 or whatever your next group is in the list.
It has worked like this for a long time.
Okay,.So it is a Feature.
But,.... i not really understand the sense behind.If i do via Direct Select Group 1 what reason can i have then select Group 2 via NEXT?Without any other order for Group 1.Normal i select Group 1 because i wanne do some with this Group...
Absolutely.
With Direct Selets, you might press the "Group 1" button, then press "+ Chan 37", the "Focus Palette 2" button, then Enter. It allows you to build up a series of stuff into one command, instead of ending the command once you click the first DS button.
