after recording cue 1, i decided to record cue .5. after completing my levels i entered (record .5) the command line automatically enters cue 1.5. is this normal? can this be fixed without entering 0.5. thanks
The reason behind this (I'm sure) is to save you time later on. If your sitting in cue 147 and you need to record a point cue you don't need to enter the cue number 147, you can just say Record . 5.
This is true for palettes and presets as well. So if the last color palette you called up was CP 30 the next time you hit color palette .1 (regardless of what you have done in between) it will post as CP 30.1.
I think this causes more consternation and takes more time to clear back than having to type 147.
Thoughts anyone?
-M
