When recording into a Submaster is there a way to not record RGB levels when their intensity is at zero and they are not selected or intended to be part of that Submaster?
Selective recording. Chan 1 Thru 10 Record Sub 1 Enter. Will not record channels 11 and up. Or use RecordOnly. Or SelectActive Record.
The sub still records the RGBW levels but Intensity is blank.
have you deleted the sub between your attempts? Eos doesn't overwrite the sub (in this case), so it might look like the syntax doesn't work although the RGBW data is just a leftover from a previous attempt.
Thanks for the help.
