In EOS 3.1.1, it seems you can't use Patch-assigned gobos in magic sheets. Given ML gobos however allow this, this is probably a bug or an oversight?
Steps to reproduce:
- make fresh showfile
- patch one dimmer fixture. Assign a Rosco Steel Gobo to this fixture (for example "50's breakup", I believe this is the first one on the first page)
- patch one moving light fixture which has a gobo wheel (for example Mac Viper)
- start a new magic sheet
- in "images" tab, go to Import, navigate to "Gobos" folder if not already there
=> the MacViper Gobos show up for import, the single Rosco gobo doesn't show up.
This leaves the workaround of saving the gobo on the computer, cleaning it up if necessary, and then importing it into EOS as a PNG. Works, but it kind of feels unnecessary since obviously EOS already has the gobo stored. In Augmented the gobo shows up just fine.
