Nomad cannot find its master with WiFi
Im trying to make a laptop connect with a Gio running  Eos 3.1.2 (same as Nomad on laptop) via wifi, but I only get either " No online masters found. Or " Previous master (Gio) Disconnected - check masters status or select a new master)
In shell it says its online with WiFi
When I'm connecting to the same network with an ethernet cable it works fine.
They are on the same subnet. The Gio has a fixed IP address , while the laptop is DHCP
Any suggestions?
