Encoder Map Bug - Map to fixture
Hello, I had a Hippo layer v4.5.3 profile in my showfile. I have created a custom encoder map for it and I love it. Now I had to patch as Hippo layer v4.6.3. So I mapped my already created encoder map to it using the Map to Fixture command. It would not correctly map to my v4.6.3 fixture unless I removed v4.5.3 from the Map to fixture list in the encoder map configuration. Removing the old layer version fixes it, and adding it back in will mess it up again and it will not work. If I have two types of layers, I will need two identical encoder maps even though I want the same parameters across both.
V3.1.2.20 on a Gio.
