hello everyone,
I am trying to create a marco to change the Timing Disable time ( see attached picture)
it does work on the foreground mode but doesn't on the background mode.
Is it possible to make it run on the background mode ? since i don't want to make the display jump in and out form the blind mode.
I know background mode marco will run as a User 0 and it might be affect the command, can anyone explain more about the limitation about the background mode marco / running command in User 0 ?
thanks a lot !
